VAFC
Old Apr 4, 2001 | 11:32 PM
bobatimez's Avatar
can u get one to lower the vtec limit? how low? 3000 rpms?
Old Apr 5, 2001 | 04:43 AM
XXXRacing's Avatar
You could, I would never lower the vtec that low...maybe going down to 5500 would work or maybe 5000. 3000 would be way to low. I have one in my gsr powered crx and installe done in my buddies 00 SI. The problem with the VAFC and lowering the vtec that low is that it takes alot of tuning to get the car to pull clean from the lower vtec point to the original. Have to really play with the fuel to get it right, not just as easy to just lower the vtec point. For warranty purposes, I would not install on eon my car. You could very easily blow up a motor with a VAFC if you aren't careful.
Old Apr 5, 2001 | 05:28 AM
derryck's Avatar
If you lower VTEC engagement below 5600 RPMS you will loose power overall. When lowered below 5600 the VTEC transition takes much longer and still does not pull like normal until about 5600 RPMS.
fishs2000
Aug 30, 2008 05:45 PM
s2khondaimport
May 19, 2004 08:28 PM
s2khondaimport
May 18, 2004 11:29 AM
mtm584
Dec 27, 2003 07:31 PM
uhear
Oct 17, 2001 03:43 PM
