Who's using Mobil One on their S2000?
Old Oct 5, 2001 | 08:50 PM
  #51
Moneeb's Avatar
First off, high octane racing fuel offers other benefits beyond detonation resistance - and it has been proven that
UL - can I take this to mean that the 2 gallons of 100 octane I mix in with every tank of 91 I fill up on are actually helping me??
Ever since they switched to 91 in CA, I have regularly been gassing up with 2 gallons of 100/tank.
Could you elaborate on the non-detonation related reasons for using higher octane gas
Old Oct 6, 2001 | 05:41 AM
  #52
ultimate lurker's Avatar
Moneeb,
There is a long thread on this in the tech forum. The short answer is yes, it may be helping you. Certainly not as much as a pure tank of 100 would though. Fuel like Unocal 100 racing is formulated to tighter specifications. It burns quicker, cleaner, more evenly and this can produce measurable power gains.
UL
Old Oct 6, 2001 | 07:50 PM
  #53
Radster's Avatar
I like the 10-30 Castrol GTX oil. It's engineered for high rev engines. If you want to go longer between oil changes.....say 5,000 + miles, then a synthetic may be best suited. I change my oil every 2,500 - 3,000 miles faithfully, and I just can't justify the extra expense on oil when it isn't staying in the car that long anyway. Castrol does it's job perfectly fine, and the hotter it gets...the better it lubes! Other oils (Thicker weights)....including synthetics, are not the way for me......I've had experiences of gum-ups on some oils, and have never ever had any problem of any kind with Castrol GTX oils. Later, RADSTER
Old Oct 6, 2001 | 08:16 PM
  #54
Kwaalude's Avatar
Originally posted by Rick Hesel
I'm using Redline for the first time and have noticed no difference in VTEC performance.
I used Redline in my '97 Prelude...expensive stuff, along with the fact that it caused my piston rings to leak!! got them replaced under warrantee but the engine was never the same. burned around 3 quarts per 3000 miles.
RazorV3
Mar 25, 2004 12:52 AM
TonyJ
Aug 27, 2003 12:04 PM
GoFaassttt
May 25, 2003 09:52 PM
schwett
May 18, 2003 07:46 PM
ricosuave
Nov 12, 2000 05:47 AM
