*Confused*
Originally Posted by shotiable,Dec 14 2006, 11:51 AM
having a CDV increases the wear on your clutch? is it hard to take out? sorry for hijacking, but im not a motorhead i'm just tryna learn new things
Originally Posted by OCMusicJunkie,Dec 14 2006, 02:20 PM
With the CDV, whenever you shift at higher RPMs, the clutch will take much longer to let out, thus creating a lot of wear. If you don't drive the car hard, it's probably a marginal difference... but if you're shifting at redline on a regular basis, it's going to take a toll.
removing the CDV doesnt remove the possiblity of slippage, u still have to get the shifting right, it takes practice and getting used to it. giving too much gas and letting off clutch too slow will slip teh clutch also. just practice
Originally Posted by blackout,Dec 14 2006, 10:25 PM
hmm got 70k on MY03 stock clutch seems to run fine and does not chirp with the CDV, never chirped, I guess it might if i didnt lift to shift....running bald tires too lol. Time for tires and or clutch?
Okay guys, let me clear up a few questions and misconceptions:
1. The belief is that the last run of 2003 S2000's DID HAVE THE CDV, so it is possible that the above poster has a CDV in his 2003 if it is a very late model.
2. The CDV will cause excessive wear, how much depends on your driving habits. If your feet-hand work is not exact, the worse it is the worse it is going to slip in the ap2. Its real easy to get back on the gas before the clutch is engaged in the ap2.
3. Billman and others have posted in the technical forum that they believe it is impossible to shift the AP2 as fast as an AP1 even with the CDV removed due to the fact the Ap2 has a heavier flywheel. This being said, if you do a clutch job definitely change out the flywheel! I went with the hardtopguy kit in mine and its awesome. No slip, just grip!
Ken_SNISEN
Jun 24, 2015 01:17 PM
