2004 engine into 2006+?
Old May 26, 2014 | 07:53 AM
EK9MAX's Avatar
Default 2004 engine into 2006+?
Looking at boosting a 2006 ap2.
Just looking down the road. If I pop the motor it looks like 04-05 engines are readily available. Would these by able to be swapped jnto the 06 no problems?
Old May 26, 2014 | 02:18 PM
chr15t0s's Avatar
you will need to use your old cylinder head or exchange the camshafts and the valve cover so you can use the different sensor form the 06+ ecu 2. you will need to remove the crankcase pulley and the aluminum plate to exchange the trigger wheel for the different crankcase sensor 3. use the dbw throttle body. that's all I know. maybe there is more you have to do good luck!
Old May 31, 2024 | 02:27 PM
Christopher huynh's Avatar
Default 2004 ap2 full swap into 2006 ap2 chassis
so i have a wrecked 2004 ap2 and found a clean 2006 ap2 chassis i was wondering how hard would it be todo the sap since i have everything from the wrecked 04 ap2
Old May 31, 2024 | 04:14 PM
noodels's Avatar
delete
Old May 31, 2024 | 05:58 PM
B serious's Avatar
To put a MY00-05 engine in an 06+ chassis...
You need to swap in the 06+ cams or cam triggers
You need a 06+ intake manifold, throttle body, and fuel rail/injectors
you need to cap off the 2AIR port on the intake manifold
you need 06+ Oxygen sensors
You need an 06+ crank trigger (remove the oil pan and front cover to do this)
You need a 06+ ECU
I think that's it
Old May 31, 2024 | 11:25 PM
Would i be able to pull everything from the wrecked 04 ap2 and just swap everything over to the 06 ap2 and just the chassis only ?
Old Jun 1, 2024 | 08:36 AM
B serious's Avatar
Sure. The entire fuel system and the wiring harness for the whole car has to change to the 04 spec. And some interior stuff.
I'm not sure that would be easier though. And it won't pass emissions
Old Jun 29, 2024 | 08:45 AM
legenyes's Avatar
You need a 06+ ECU
I think that's it
How about the opposite way?
I had a 06+ F22C comple engine and a 04-05 cylinder head as well. (because short block is damaged)
Can I only replace the crank trigger wheel then put the 06+ engine onto my 2004 S2000?
I read so many article but did find very firm answer.
Old Jun 29, 2024 | 03:20 PM
B serious's Avatar
Check my post. Where I say "06+", replace it with "04"
Jdmjeckjeck
Nov 24, 2018 05:15 AM
jdmdohcpower
Sep 16, 2017 08:41 AM
K0002S
Dec 24, 2016 09:49 AM
06s2000
Jun 7, 2011 05:45 PM
cts-tom
Apr 20, 2009 03:06 AM
