3rd gear
hey i got a question about my s2k 3rd gear, whenever i do high rev on 2nd gear and switch to 3rd, the gear grinds, also when i down shift to 3rd it grinds? i was wondering if this is normal? anyone help?
is it grinding, ir is it rough going into gear? Mine was a little rough going into gear, and i changed my tranny fluid and it fixed it right up. It is pretty cheep if you do it yourself and probally not a bad thing if you havent done it in a while.
-Ian
-Ian
3rd gear is notchy on every s2000, however, grinding is not normal. While tranny fluid replacement may temporarily alleviate the problem, this is ALWAYS a mechanical issue (synchro) that needs to be addressed.
lunardeathgod
Jun 19, 2012 03:47 AM
change your tranny fluid out first and see if that helps any.
