About to purchase ap1 - quick questions
http://www.blackstone-labs.com/
Prep I did for my AP1.
Intake Retainer upgrade to AP2.(exhaust is good as is) and good close look at all exhaust retainers.
Upgrade banjo bolts(that's for you)
Test Pipe
Catch Can setup
Wideband and Boost monitoring system
Upgraded fuel pump(my setup is higher than yours)
Upgrade fuel pump wiring.
Injector upgrade
Map Sensor Upgrade
I will be putting in a dedicated oil return line to the pan but that's not mandatory.
I have an '04 Tranny and '06 Diff so those are "upgraded a little over AP1's)
When they put the head back on an upgrade to APR studs is probably in order. And root cause of the burnt valve would be good to know.
Probably a couple other things I am missing but that's about it.
Test Pipe
Catch Can setup
Injector upgrade
Map Sensor Upgrade
Quick update --- they ended up pulling the head off and it was only the piston sleeve and ring of cylinder 4, the machine shop fixed it and valves were fine. Wasn't too bad $ wise but question I meant to ask that I didn't have a chance to.
When you pull the head and have some machine work done do you have to rebreak in the engine or are you good to go? Just trying to figure out how I should be driving it for now and for how many miles???
Got lucky on tbis one very grateful and I had APR head studs installed as my first prep for the sc setup down the road, can't wait to get the car back! Only 15 degree weather and snow on the ground... should be a perfect day to ride with top down
Blackstone Labs
Test Pipe
Catch Can setup
Injector upgrade
Map Sensor Upgrade
Test Pipe
Catch Can setup
Injector upgrade
Map Sensor Upgrade
hey man just curious did you just opt out for oem injectors or did you go aftermarket?
9000 redline
May 16, 2008 09:02 PM
