? about replacing the window auto-down regulator
Old Jan 20, 2009 | 12:50 PM
Elistan's Avatar
Default ? about replacing the window auto-down regulator
My auto-down on the driver's side window has stopped working. The reset method in the DIY has no effect, so I assume the regulator needs replacing.
Here are the instructions in Honda's TSB.
https://www.s2ki.com/shared/library/...-008/index.htm
It looks like it requires some careful alignment to make sure the window works properly after replacement. I'm not too good at such work. Has anybody else replaced the regulator themselves, and if so how hard was it to put everything back the way it should? (Along those lines, what should be used to re-seal the plastic door liner?)
Thanks!
Old Jan 20, 2009 | 03:39 PM
tekstar's Avatar
a local and i replaced my driver's side regulator for the same reason. i'd say it took us a good 20 mins putting everything back together. one person to hold the window up, the other person to tighten everything. not too bad... then again i wasn't the one doing all the work
we reused the glue that was already there to reseal the plastic door liner
Old Jan 20, 2009 | 07:19 PM
Elistan's Avatar
Did you have to heat it, or did it just stick back on its own?
Old Jan 20, 2009 | 09:14 PM
tekstar's Avatar
it stuck back on its own
Old Jan 20, 2009 | 11:18 PM
AlX Boi's Avatar
Not to thread jack, but would this be the same process to convert the 2 other window switches to have auto-up as well? What about the process to make auto-down?
Alps Pacino
Apr 4, 2017 10:18 AM
Feuerrader
Feb 28, 2013 01:59 PM
ronver
Jul 12, 2011 08:12 AM
vstypicals
Apr 23, 2010 08:03 PM
Mugen112
Feb 29, 2008 08:51 PM
