ABS code - faulty solenoid
Old Jun 27, 2017 | 09:40 AM
s2k_4life's Avatar
Default ABS code - faulty solenoid
So I just pulled the abs code with the 4 - 9 method and got the following codes:
1) 61 - ignition voltage
2) 13 - wheel senor (open/short to body ground/short to power) FL
3) 32 - solenoid (short to body ground/short to wire) FR-OUT
4) 34 - solenoid (short to body ground/short to wire) FL-OUT
5) 37 - solenoid (short to body ground/short to wire) RL-IN
What do you guys think? It seems like there is an actual problem with the ABS module itself. Any other way I can test the system before spending the money on a replacement unit? I also recently replaced the FL wheel sensor not too long ago, so its weird how it came up as well. Faulty Harness? Corrosion?
Any help will be appreciated!!
Old Jun 27, 2017 | 09:51 AM
Langelo DeMysterioso's Avatar
Just bought a replacement for my ABS module.
Look for a used one. New they run $1,600.00 - $2,200.00. they can be found on Ebay for less than 200 bucks depending on unit number and model year could be as low as 75 bucks.
No the Honda (ATE) units are not rebuildable so this is not an option.
orchard
Oct 23, 2017 11:18 AM
StormTroopinAP2
Oct 12, 2012 03:50 PM
vader1
Jul 7, 2009 06:54 PM
Hyper_R
Jun 23, 2008 10:57 PM
bbanbrook
Jul 28, 2006 10:02 AM
