ABS help?
Old Oct 25, 2012 | 07:55 AM
spinks's Avatar
Default ABS help?
so long story short... I introduced my driver rear wheel into a curb. They didnt take kindly to one another. Ive replaced everything in the rear, just need end link for the sway bar. here is the problem i need help with. when slowing to a stop, once i slow to 11mph and the brake pedal gets hard as if the abs is activating. anyways...could this be the rear sensor? i havent replaced it. but want to be sure thats it before i do. is there a way to test it? also the steering isnt 100% after turning the steering wheel use to return back to center.. and i have to turn it back myself....any advice or help would be appreciated
Old Oct 25, 2012 | 11:06 AM
trP's Avatar
trP
Replace the sensor if its showing the ABS light, the ! light and the VSA light. I had a similar issue. I had all 3 lights, checked my speed sensor and it was loose. I secured the sensor and the lights went away, braking was normal.
Old Oct 25, 2012 | 11:57 AM
jsenclosure's Avatar
does it make a ERRRRR sound? i have a lose abs sensor on my front hub i need to set in a little lower. It makes the ERRRR sound when braking (pulsinf pedal) for the first stop, then the light comes on and it disables abs
Old Oct 25, 2012 | 01:12 PM
spinks's Avatar
abs light comes on very rarely. no errr sound, just the pedal pulsating. no vsa light at all. how much are these sensors?
Old Oct 25, 2012 | 01:38 PM
dwight's Avatar
Is your profile correct? Do you have a 2001 S2000? If so, you're not going to have a VSA light come on any time soon.
http://www.hondaautomotiveparts.com/...REAR+LOWER+ARM
57475-S2A-003 020 001 SENSOR ASSY., L. RR. 141.27 98.89
Old Oct 25, 2012 | 02:23 PM
spinks's Avatar
yes its a 2001 s2k. ap1. 127k miles
Old Oct 25, 2012 | 02:25 PM
spinks's Avatar
those prices are high compared to the local parts store
Old Oct 25, 2012 | 04:02 PM
dwight's Avatar
Then buy it locally if you want, but it's comparable to what I've found online and is from a very reputable dealer.
http://www.rockauto.com/catalog/x,ca...Speed%2BSensor
http://www.amazon.com/Standard-Motor...art/B004J9FBFM
http://www.hondapartswebsite.com/OEM...475S2A003.html
goofy
Oct 18, 2017 01:38 PM
LilSeggs
Aug 2, 2009 01:41 PM
FOXCONN4
Nov 29, 2006 07:57 PM
kMfromLA
Jul 19, 2006 03:35 PM
intake
Aug 17, 2004 10:15 PM
