AC Intermittently Blowing Cold
Old May 2, 2016 | 05:50 PM
roel03's Avatar
Default AC Intermittently Blowing Cold
I've been having AC issues with my car since I've owned it, and I was looking for some advice. The AC blows cold for about 20 minutes, then ambient air for about 30 minutes, then back to cold. Anyone know what could cause this?
I tried charging it this weekend with one of the off-the-shelf kits, but the pressure was right where it should be.
I never use my AC since I always have the top down (probably what caused this), but have been using the highway more often recently.
Thanks in advance.
Old May 2, 2016 | 06:57 PM
Gotpepsi's Avatar
Thanks in advance.
How did you charge the system? Did you have the car turned on with the AC blowing at maximum level?
Old May 3, 2016 | 04:52 AM
Slowcrash_101's Avatar
Water in the system, your expansion valve ices over and blocks refrigerant getting into the evaporator. Get the a/c charge evacuated and change the drier, your symptoms are only going to get worse.
Old May 3, 2016 | 12:47 PM
roel03's Avatar
The AC was at full blast and car running of course. Ended up not charging it since it was already full.
I will look into a replacement drier.
jaundice
Jun 6, 2010 01:06 PM
Pointblank
Feb 2, 2009 04:05 PM
nearwater4me
Aug 10, 2007 07:19 AM
6million$man
May 8, 2004 11:48 PM
Seks
Jul 13, 2002 09:49 AM
