Accessing rear taillights on an 02
Old Jul 14, 2010 | 06:39 PM
S2kRob's Avatar
Default Accessing rear taillights on an 02
All,
Quick, easy and maybe obvious question.
How do you access the rear taillights from inside the trunk? There are these plugs with plungers in the centre of them holding in the trunk lining and I just want to know how best to remove them without breaking them.
Many thanks!
Old Jul 14, 2010 | 11:24 PM
toniotran's Avatar
I believe you'll need to push in the center (plunger) in, then you should be able to take out the plastic clips using a flat screw driver.
Old Jul 15, 2010 | 12:03 AM
Rdizzle's Avatar
Careful, don't push the "plunger" in as it can fly into the hollow metal space of your trunk if pushed too hard (then lost forever). These little snaps are about $4/ea to replace.
Instead, use a very small screw driver or needle to pull the center piece out. Then the snap comes off easily. I find that pulling is easier than pushing for the trunk.
Old Jul 15, 2010 | 06:09 AM
S2kRob's Avatar
Thanks guys! Didn't know whether to push or pull. I'll give it a shot tonight!
Bored_Rice
Jul 22, 2010 05:29 AM
WeezyBaby
Jan 24, 2008 04:33 PM
ericshun
Oct 25, 2007 11:21 AM
freak21s2k
Aug 2, 2007 05:05 PM
