AEM UEGO
Old Aug 30, 2005 | 06:45 PM
spoiled@21's Avatar
Default AEM UEGO
Just curious to see where some of you guys routed the harness from the O2 sensor to the back of the gauge. I have a gauge type w/ controller built in and it is going in a SOS a pillar pod. Seems like I have plenty of cable but I almost never found a place to run my laser shifter wires through the firewall. Is there any access under the car?
Thanks in advance.
alex
Old Aug 30, 2005 | 10:24 PM
folex187's Avatar
Not exactly how I want to do mine but a possible rout:
https://www.s2ki.com/forums/index.ph...&f=71&t=267255
I was thinking maybe where the wires cross through by the battery. The only problem is I can't find where they actually enter the cabin nor can I figure a way to go through the dash...
Old Aug 31, 2005 | 05:12 AM
Ztec's Avatar
Here is a good write up on the uego,
https://www.s2ki.com/forums/index.php?showtopic=175549
If you have the Gauge type the orange wire reffered to in this post is actually the White wire on the Gauge type to pin C16. The monster clip for the sensor can be removed (it was grey in color on my connector and the actual connector was black), Remove the gray clip to make the connector smaller then I dremmeled out an existing hole in the fire wall just big enough for the plug then put the grey clip back on! Here is where I put my Gauge - Next to the start button.
Middlesbrough
Jul 3, 2013 03:47 PM
o'malley_808
Feb 19, 2009 08:21 PM
ian_6301
Car Talk - Non S2000
May 11, 2008 11:20 AM
Silver9k
Dec 16, 2005 07:59 AM
Silver9k
Dec 15, 2005 08:02 AM
