AEM V2 & CEL Light
Old Dec 20, 2004 | 09:50 AM
USCstudent's Avatar
Default AEM V2 & CEL Light
I just installed my AEM V2 and after about a day of driving the check engine light came on. I didnt reset my ECU after install so this may have been the cause of the problem. But in any case could some walk me through the process of resetting it or tell me another way to get the light off
Old Dec 20, 2004 | 10:15 AM
Gernby's Avatar
Former Sponsor
Pull fuse #25 (7.5A at 3rd position from the top on the right) for 30 seconds with the key out. Although, that probably won't fix it. It sounds to me like you crossed some vacuum hoses.
Note: the 1st position at the top right is usually empty.
Old Dec 20, 2004 | 10:27 AM
pantyraider's Avatar
If it came on after a day of driving, then there is probably something wrong that you should check out. Maybe your vacuum hoses are loose .
Old Dec 20, 2004 | 11:04 AM
xviper's Avatar
Follow this thread:
https://www.s2ki.com/forums/index.php?showtopic=105368
Trace the lines step by step and note the white check valve orientation.
Old Dec 20, 2004 | 11:17 AM
Gernby's Avatar
Former Sponsor
You should probably go by Autozone to have the OBDII code pulled before you clear it.
Old Dec 20, 2004 | 04:38 PM
USCstudent's Avatar
My problem has been rectified. I had some of the vacuum hoses crossed up - who woulda thought..... Anyhow thank you guys for the help it is greatly appreciated
Old Dec 20, 2004 | 04:53 PM
Gernby's Avatar
Former Sponsor
[QUOTE=USCstudent,Dec 20 2004, 07:38 PM] who woulda thought.....
FluKy15
Jul 11, 2011 08:42 PM
doinou88
Feb 10, 2008 06:55 AM
outcrnru
Jul 20, 2006 07:51 PM
ac09lude
Jan 18, 2005 03:01 PM
trigeek
Dec 18, 2003 06:03 AM
