Another Camber/Toe Problem
Old 08-02-2006, 08:31 PM
S2KL33N's Avatar
Default Another Camber/Toe Problem
Went to the alignment shop today, only looking for near OEM results for a daily driven S2K. Car is dropped 2" with 18" wheels. I expected more negative camber due to the tire height and here are the results:
LF:
Camber -1.4 (-.7 to -.3 specified range)
Caster 6.2 (5.8 to 6.3)
Toe -.46 (-.08 to .08)
RF:
Camber -.7 (same above)
Caster 5.7
Toe -.37
LR:
Camber -2 (-1.7 to -1.3)
Toe -.44 (.16 to .32)
RR:
Camber -2.3 (same as above)
Toe -.6
Rear thrust angle: .08 degree
Are you getting the same results? I'm really concern about the toe degree both on the front and rear. Did you buy the expensive bumpsteer or did you only need the camber kit from either Eibach or SPC, also if you pick up the camber kit, did you get the adjustable rear toe arm too? My last set of tires lasted less than 10K miles.
Thanks!
Old 08-02-2006, 09:31 PM
jzz30's Avatar
what eats alot of the tire is toe. camber accelerates wear but not as much as toe. bump steer kit allows your car to maintain a straighter toe than a car without under compression of the suspension. a camber kit is your only solution if you want to get rid of it. but i dont see much harm in having 1.5*F and 2*R
Old 08-02-2006, 09:40 PM
rlaifatt's Avatar
Are those the results AFTER an alignment? There is no reason why the Toe can't be adjusted to spec. If that's the best they can do, then raise back your car.
Old 08-02-2006, 09:42 PM
S2KL33N's Avatar
From other threads, -2 degrees of camber seems normal. If toe correction is really that much off, am I better off with adj. toe arms than? Or are you saying just go with camber kit to slightly correct both? Thanks!
Old 08-02-2006, 09:45 PM
S2KL33N's Avatar
[QUOTE=rlaifatt,Aug 2 2006, 09:40 PM] Are those the results AFTER an alignment?
Old 08-02-2006, 09:53 PM
rlaifatt's Avatar
It's normal that toe, camber, and caster change when you change any one of them; especially camber and toe in the rear. Has this tech aligned S2000's before?
BTW. -1.5 front and -2.0 rear is good for street. Need to get 0 toe in front, and 1/8-1/4" total in rear.
Old 08-03-2006, 06:07 AM
mxt_77's Avatar
Originally Posted by S2KL33N,Aug 3 2006, 12:45 AM
Yep, that was after. Tech said he can't adjust the toe unless it effects the caster or camber.
Yeah... so???
Take it to a different tech. I'm pretty sure that even with your drop you should be able to align the car to factory specs (assuming the tech knows what he's doing).
Old 08-03-2006, 06:30 AM
Joel S2k's Avatar
dont feel bad, ive got the same problem with my 17's...my front is 1.5 and rear is 2.5 but i think my toe is pretty bad that makes my car eat more tires...my car has 8k on them and front tires(inside shoulder) is almost bald because of my toe...im goin back to my buddy to get them checked...but for some reason, my rear tires is really good as far as wearing out. It shows a little camber wear but thats really normal on rwd cars. My front is my biggest problem now...
Old 08-03-2006, 03:37 PM
22calbr's Avatar
i got the same problems. need to get rid of some toe up front.
Old 08-03-2006, 07:14 PM
jzz30's Avatar
you should be able to adjust front toe independantly from any other adjustment. the rear may be a different story but im not sure about that.
Popa
10-29-2011 09:05 AM
Flapjack
03-29-2011 10:42 AM
datbird
11-02-2006 09:26 PM
kiltbunny
07-25-2006 05:19 PM
TunedS2000
01-14-2005 07:06 AM
Quick Reply: Another Camber/Toe Problem
