Another engine noise topic
Old May 6, 2015 | 01:14 PM
Em2jdm's Avatar
Default Another engine noise topic
Hey guys got this noise going on with my engine.
Car Is Turbo with 67k miles only 2k miles boosted
Just got the head built:
Supertech inconel valves in/ex
Supertech dual valve springs
supertech TI retainers
Supertech Bronze valve guides
Supertech dual valve spring seats
Supertech Valve seals.
everything else is oem on engine
Just replaced TCT with new OEM
Set valve lash cold to .23mm intake and .27 ex.
seems like the noise is too cyclic to be rod knock but I am not sure.
[media]http://youtu.be/Os-UFZ6rsX8[/media]
~Chris
Old May 6, 2015 | 01:38 PM
windhund116's Avatar
Perhaps, recheck those clearances. May have loosened up.
Old May 6, 2015 | 06:16 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Agreed something is not right in the top end, I can't make out any low end sounds.
Old May 7, 2015 | 08:09 AM
Em2jdm's Avatar
Billman Any Ideas?
I checked Valve Lash Again cold and its still in spec.
Tappets? Cam messed up? Any Ideas?
When I take spark off Cyl 4 it gets quieter.
Old May 7, 2015 | 02:41 PM
Billman250's Avatar
Top Answer: 1
Possible scored #4 cylinder. Get a bore scope down the plug holes and look where the piston skirt rides. Will appear as wide black marks.
I don't trust any of those cylinder head components and I'm confused why so many people do it.
Old May 8, 2015 | 11:15 AM
Em2jdm's Avatar
Billman... Have you seen alot of problems with that valvetrain kit?
IF so what kinds?
JB Morrison
Oct 17, 2018 05:09 AM
revto9k
Sep 26, 2011 11:47 AM
jonnys2k01
Dec 1, 2008 05:17 PM
jonnys2k01
Nov 10, 2008 05:47 AM
abv
May 13, 2006 02:04 AM
