Any harm with 6qts of oil?
#21
^^Dlg04 is right. As long as you are within the hash marks you will be fine. usually the saying goes, its better to be a little low in oil than to be a little over. This is because the crank can whip up the oil as S2000nvegas stated. This causes the oil to start to foam and your oil pump can't pump foam for optimal lubrication.
#24
you won't get windage with 6 quarts, the design of this race engine puts the crank above overfill
oil pressure guage will tell u if overfill is needed. higher the rpm, the more oil in engine and not in pan.
oil starvation occurs repeatedly with lateral g's on the track with standard pan even with overfill in my car
#25
Originally Posted by s2kmaniac81,Nov 2 2005, 11:18 AM
I have always checked my oil when the engine is fairly cold because all the oil has had a chance to drain into thte pan and you get a more accurate reading.
Yes there could be some variation with the amount of oil in the engine when warm. But the designers have tested the system to minimize variation.
With this be a critical issue? Unlikely but it is not correct to say that a cold reading will be more accurate if the oil is intended to be read hot. You will read higher when it's cold.
#26
Let me settle this
#27
Originally Posted by Tugz_S2K,Oct 30 2005, 10:42 AM
as well you can damage the
catalytic converter with too much oil in the pan.
BTW 5.5 quarts for me.
#28
If you have so much oil in the engine that oil is standing above the valves, the valve stem seals won't be able to stop oil from getting pulled into the combustion chamber. It could damage the convertor, from burning LOTS of oil. The car would smoke horribly all the time and take a few gallons of oil to do this.
