ap1 ap2 oil cap
Old May 18, 2007 | 06:13 PM
R3DS2K's Avatar
Default ap1 ap2 oil cap
correct me if im wrong but from other post a long time ago. i read that ap1 burned a little more oil than ap2.
now the real question i just was wonder after buying some oil for an oil change and couldnt find my 10w30 as recommend on my 06 s2000 oil cap.
could someone with an ap1 check your oil cap and tell me if it says 5w30 or 10w30 ??
since 5w would burn more than the 10w
even tho it seems like its not much in difference. but it is..
proof
at work.. 2007 toyota camry 4 cylinder uses 0w20 or 5w20 .. due to a tighter tolerance
well at 15000 miles someone in shop put 10w30 oil in it.. 5k later at 20000 miles he comes in for another oil change plus he says it it runs kinda slow.. i did some research and found out at 15k some1 put the wrong oil weight as i said before.. just before he leaves.. i also found out that he was even slower when it was in the morning when it was cold..
i know that alot of hondas are going to 0w-20 as well. the civics the only one i know now
but as you can see. running the non recommend oil = no good
Old May 18, 2007 | 06:16 PM
iam7head's Avatar
it's 10 w 30 for us too
i am very surprise you can't find 10w30, that's like more common than coke in the world of automotive oil.
switching to 5w30 will not affect much to be honest, the visocity will be lower during start up(cold) or winter, but once it's in operation range, it's all the same.
for the peace of mind, just look for 10w30.
Old May 18, 2007 | 07:34 PM
RedY2KS2k's Avatar
RTFM.
Old May 18, 2007 | 10:01 PM
R3DS2K's Avatar
Originally Posted by RedY2KS2k,May 18 2007, 07:34 PM
RTFM.
soooorrrrie i dont have an AP1 manuel. . since i have a 2006..
and the reason i couldnt find 10w30 was .. i buy the 5 quart jugs at walmart .. moble1 for like 23$ so its cheaper.. but i ended up buy a 6 quart box of moble1 and it came out to be 35$ plus tax.. i was like no.. its suppose to be 30$.. but that was along time ago and i told the casher.. she called someone and i ended up giving it to me at that price ahha.. i went back and checked.. it was in the wrong stop andi got the last one.. oh wells. i win .. but thx for the info
S2000_916
Nov 4, 2014 01:31 PM
noyamil
Mar 14, 2012 06:11 AM
JEEBS
Apr 23, 2011 02:47 PM
Wydget
Feb 28, 2011 10:44 PM
bboixtc
Apr 25, 2009 07:05 PM
