AP1 S2000 Engine ticking - Stumped!!
Yes, i got absolutely nothing. After around 5 seconds the engine would start running pretty rough and i would put the coils back in but i assumed that was normal for the counterbalance of a dead cylinder. No immediate changes in any cylinders.
It's very hard to tell from video. I have people ask me to listen to video all the time. Usually cant tell much. That being said it sounds solid but upper end to me from video. Don't forget that I am in Lexington and have many connections here. If it is lower internal, a used oem is what I think is best solution. I was a heavy line gold level Honda dealer tech then shop owner before retiring.
Is this your first time performing a valve adjustment? Also, did you use a valve adjustment tool?
I would guess that the valve adjustment may not have been done correctly.
Did you find that any of the valves were loose when you performed the adjustment?
Yes, this is my first valve adjustment and it may very well have been done wrong. I personally found that nearly all of the valves were very tight and I ended up loosening most of them(and some of them quite a bit) to get it where it is now. I just used a wrench and a flathead screwdriver. I set everything to factory specs with bent feeler gauges, followed a guide somewhere on here as best as I could. Something weird I did notice was that when i would finally be able to get the feeler gauge in between the valves, there would almost always be some play in it in order to get the feller gauge in. As in, when i managed to find the slot between the valves and get the gauge in, the upper part of the valves when lift up a slight amount to make room for the feeler gauge. I personally found this to be a little bit strange, but may very well be normal.
Yes I am sure he will be a great help, hard to find anyone local who knows anything about these cars.
The valve clearance you are measuring is the distance from the rocker arm adjuster to the valve stem tip with the rocker moved to the top of it's travel without the cam lobe acting on it. This clearance reduces as the car gets warm, even when the car is fully warmed there should be a tiny amount of play.
The reason for the play is two-fold, 1.) it allows the valves to fully make contact with the valve seat. 2.) It reduces resonant frequency in the valve train.
The people that go nuts when they hear a little valve chatter are over worrying, you'll do far more damage to your engine having the valves too tight than too loose. I rather live with a little chatter than live with the noises I'll be making as I'm pulling the head to replace valve guides, seats, and seals.
Most Porsches also have rigid mechanical drive trains that require frequent valve adjustments, and when it's just done, the engine sounds like it's going to fall apart. Except for the new 911 GT3, they have rigid valve trains like our cars but they have valvetrain witchcraft that lets them have 186,000 mile valve adjustment intervals.
