Ap2 p0339 code
Old Feb 10, 2014 | 08:04 PM
05lagunas2k's Avatar
Default Ap2 p0339 code
Hey guys i have a 05 s2000 and for some reason i have random p0339 code i already changed the crankshaft sensor with an new oem and it still does it any clues
Sent from my iPhone using Tapatalk
Old Feb 11, 2014 | 05:39 AM
Gottabfast's Avatar
Follow/trace the wiring harness to the ECU to look for any damage. Do you have a stock ECU?
Any mods or recent work done (other than the CKP)?
Old Feb 11, 2014 | 08:10 AM
Yea i have the stock ecu and no new mods
Old Feb 11, 2014 | 11:30 AM
It started to do it when it got really cold down here.If i turn off the car and turn in on again it runs good even though it has the cel
Old Feb 11, 2014 | 01:58 PM
c130turboprop's Avatar
did some searching for ya. u said it started after it got cold down your way. maybe your battery is getting weak. I googled that code and it says sometimes a weak battery can cause this or a weak starter motor. heres the link http://engine-codes.com/p0339_honda.html
id be willing to bet if u change your battery and clear that code, it wont come back. its probably sensing a hard start and throwing that code. also check and make sure the ground on the back of the head is still tight and clean, that's where the crank sensor and all engine sensors/ecu circuit ground and wiring shielding/ecu logic grounds are all grounded at...
Old Feb 11, 2014 | 04:31 PM
Ok ill check that tomorrow thanks
Old Feb 12, 2014 | 03:12 AM
S2kPowa's Avatar
Did you reset ecu when changed sensor?
Old Feb 12, 2014 | 05:35 AM
Yea i disconnected the battery and pulled the ecu fuse
Old Feb 13, 2014 | 01:02 PM
I looked at it and i think its the ground cable on the drivers side.i called honda they are on backorder
Old Feb 13, 2014 | 04:31 PM
to find out, take jumper cable and put one end on the battery neg terminal and other end on a good ground on the body and start it and see what happens
THE REAL DEAL.
Oct 23, 2015 01:12 PM
Muzzsjm
May 27, 2010 08:40 AM
Sartis
Nov 9, 2009 08:57 PM
legin_k
Nov 6, 2009 01:19 PM
r8byb
Apr 15, 2009 09:17 AM
