Apexi-v-afc
Old Feb 18, 2002 | 01:05 AM
jays2000's Avatar
Default Apexi-v-afc
Hi i need help about how to work with one of the function i the VAFC. do i have to set the vtec unmatch fuel correction. i don't understand how to set it to +2% or leave it 0% anyone please help me or advice. thank you
Old Feb 18, 2002 | 08:24 PM
RWD_RCKT's Avatar
I hate to volunteer the services of another member without their permission, but give RT a private message and ask him. HE IS A WEALTH OF INFORMATION for the VAFC.
Old Feb 18, 2002 | 11:15 PM
RT's Avatar
RT
[QUOTE]Originally posted by RWD_RCKT
[B]I hate to volunteer the services of another member without their permission, but give RT a private message and ask him.
Old Feb 19, 2002 | 05:27 AM
marcucci's Avatar
Originally posted by RT
BTW, the more I learn about the V-AFC the less I tend to recommend the mod (nice piece of engineering/electronics anyways)
Why?
Old Feb 19, 2002 | 06:46 AM
RT's Avatar
RT
Two main reasons I feel it's not a "great" mod:
- V-AFC doesn't control ignition timing which you need to effectively change the VTEC point,
- Day to day drivability suffers due to the fact you're stuck with a static VTEC change over point with the V-AFC while the Honda ECU is variable (engine doesn't run well in the mis-match zone which can get big if you're not at WOT).
It can definitely raise your WOT dyno curve (for the bench racers out there) but in my opinion the added HP isn't worth the degradation in drivability. However, fact of the matter is, I still run one and have no plans to remove it until someone come out with a plug and play S2000 ECU that can handle boost (AEM?), so don't listen too hard to me
Old Feb 19, 2002 | 07:01 AM
RWD_RCKT's Avatar
I hate to change the subject from jays2000, but what if you keep the VTEC set point at 6000 with the VAFC? Will that keep the driveability?
Old Feb 19, 2002 | 07:40 AM
johnR's Avatar
I put the vtec to 6000 and there is still a mismatch. If you look at your VTo and VTi and you're just cruising, not WOT, there is still a mismatch.
Old Feb 19, 2002 | 10:56 AM
RT's Avatar
RT
[B]I hate to change the subject from jays2000, but what if you keep the VTEC set point at 6000 with the VAFC?
rikhemi
Jan 14, 2008 02:28 PM
tenblade2001
Aug 5, 2003 09:54 PM
payyourtoll
Jun 23, 2003 06:18 AM
ZAMBONO
May 22, 2002 12:25 PM
PsychoBen
Feb 4, 2001 06:38 AM
