Back from round two of mat testing...
Originally posted by ultimate lurker
My goal is to permanently bypass the TB, while inserting a couple of valves in the IAC coolant circuit. UL
I 'tested' the sunshade by placing some extra I had on the hood of a Suburban while the hood was hot. The nonhood side had quite a temperature difference from the side placed on the hood, so the shade does act as a heat insulator of sorts. For now, I'll keep the makeshift shield as is; a portion is double ply anyway from the extra around the radiator cap.
Hey Tedster, this bud's for you.
My latest mod is the "snorkel". It's made from 6" diam. flexible ductwork. I took a piece of the thing on the left to make the thing on the right:
I mounted it behind the grill. (view from the front):
The following is where snorkel comes "out". Also, my final heat management mods, double wrapped intake tube, wrapped upper rad hose and the "rad mat".:
Finally, the exhaust heat shield (which I may later replace with more expensive and better performance exhaust blanket):
xviper, I was actually thinking about using those ducts to shield the intake tube... but I have yet to figure otu a good clean way to work around the various hoses that comes out of the intake tube.
-Shing
-Shing
-Shing
-Shing
I have just acquired a lab grade hi temp thermometer which I have installed on the surface of the intake manifold just next to the IAT sensor. I'm just on my way out now for a drive. I'll take some readings along the way. I just wanted to see how this compares to the IAT readings you've been getting.
Readings of surface temps of intake manifold. For ease of comparison, I've converted to *F.
Ambient temp: 109* in the sun.
After 30 min drive: 154*
After shopping for 10 min: 181*
After 5 min drive home: 162*
Sitting in garage for 1 hr: 145*
99SH
Oct 15, 2018 08:24 AM
