BBK/ Heat Sheilds/ Track work
Old Sep 26, 2009 | 02:31 AM
E4RTH WORM JIM's Avatar
Default BBK/ Heat Sheilds/ Track work
I have just fitted a 330mm BBK and found my studs arn't long enough when I have my spacers and wheels fitted .
When I fitted the BBK I removed the heat sheild from the car. The rotors are about 8mm away from the rod end rubber boot/cover. There is also the ABS sensor which is close by!
Is this going to be a problem? When on the track will the generated heat from the rotors melt them?
Any advice is welcome, thanks
Old Sep 26, 2009 | 09:08 AM
jeggy's Avatar
nope. unless your rotors are GLOWING RED with heat, they won't melt.
Old Sep 26, 2009 | 11:57 AM
terahertz's Avatar
some of the track guys who remove the heatshields wrap the rubber with some heat reflective/insulated stuff.
if i remember correctly, the heat will dry out the rubber and will make it brittle faster, resulting in the rubber cracking eventually, but sooner than if you had the shields or something protecting it.
Old Sep 27, 2009 | 04:34 AM
Thanks for the response's so far!
Can anyone recommend any heat protective film/wrap?
RedCelica
Oct 21, 2016 06:23 AM
mzk784
Jul 24, 2012 08:44 PM
E4RTH WORM JIM
Sep 29, 2009 05:54 PM
Ajjra
Oct 26, 2004 01:51 PM
Luis
Jun 13, 2003 06:46 PM
