Blown.
Old Dec 14, 2015 | 08:42 PM
Chong's Avatar
Default Blown.
Welp.
Old Dec 14, 2015 | 08:43 PM
Chong's Avatar
Oh wow. After welp I put an emoji followed by a paragraph. Idk if my phone is tripping but only welp posted? Let me go type that novel over again..lol
Did some research with the search feature but pretty much only found out f22 into an ap1 isn't worth it.
'02 s2k's engines blown. I was quoted at 6400 by the shop to replace it. But I'm wondering if I find a slightly used f20 if I could get it done cheaper. I've never swapped an engine myself but I'm debating it to save some money. I guess what I'm asking is the rate of difficulty for the labor; or if I should just let the pros do it. And a reputable source for an f20.
Old Dec 14, 2015 | 10:43 PM
Soviet's Avatar
If I were you I would source the motor yourself and shop around for labor prices.
I spun a rod bearing in an F20C and bought an F20C with 111k miles with good compression for 2k shipped.
I then had a friendly cash only garage do the swap for $600. They broke the knock sensor but still not bad.
I then proceeded to part out my busted motor and got nearly $1k back for a net loss of $1600 and a bit of my time, but it was fun!
If you are going to swap the motor yourself you will need some tools. An engine crane at the least.
Old Dec 15, 2015 | 12:32 AM
windhund116's Avatar
Bottom end, top end? Seized-up? Or just valves shot?
Old Dec 15, 2015 | 03:41 AM
AE_Racer's Avatar
I spent $2200 on a super low mileage 05 F22 long block and swapped it myself. Think I found the motor on a S2000 facebook group.
$6400 seems high. Unless they're paying $4-$5k for a motor.
Old Dec 15, 2015 | 05:31 AM
Topplayer's Avatar
unless they are getting a new short block thats steep, even then if you are handy do it your self, I did it on my street car. Might take you awhile but you learn a whole lot if you take your time
edit: if its a top knotch shop I can see that price, sometimes to get the best you gotta pay.
Old Dec 15, 2015 | 07:46 AM
Slowcrash_101's Avatar
Putting in an F22 is pretty easy, as long as it's an 04 05, it's better to swap in the the 04-05 ecu, but you can use the current one, just be mindful that rev limit is lower and going to 9k is a quick way to destroy the engine.
F22's go for about $3k
Old Dec 15, 2015 | 06:22 PM
PaddyMcP's Avatar
I spent $2800 on a 36K mile 2.0 and thought it was a great deal. Verified the mileage with the vin and checked under the valve cover and oil pan. All looked good. 6 month warranty from the junk yard.
Old Dec 16, 2015 | 01:40 PM
Car Analogy's Avatar
This has got to be one of the easiest cars out there to do a motor swap. So if you are ever gonna learn to diy, this would be a good time to try.
$6.4k to do a motor swap is robbery, even if its a brand new block.
As mentioned, if you swap an ap2 motor into an ap1, gotta swap the ecu too, so you don't over rev it, and burn out new motor.
Sent from my SM-G920P using IB AutoGroup
freshcheck
May 15, 2015 04:39 PM
seoul2k
Jul 25, 2013 03:21 AM
redes2k
Jul 28, 2008 07:25 AM
fastcrs
San Diego S2000 Owners
Apr 15, 2008 01:09 PM
RSXelrate
26
Dec 6, 2006 02:43 PM
