blown head
Old Nov 13, 2006 | 04:45 PM
s2kgash's Avatar
Default blown head
ok longgg story,ill try to make it short I had a head rebuild due to bent valves, then honda does the valve adjustment, 3 months later valve drops into pisons and comes out the block i was driveing 50mph in nyc does anyone know what could of happend? dealer said it was the machines shops fault due to loose retainers or valves but can they do a valve adjustment on the motor if that is true? i put 3000miles in the 3 months and never drove it hard pleaseee someone help warrenty doesnt want to pay for it either thankkks
Old Nov 13, 2006 | 05:42 PM
Slows2k's Avatar
The shop doesn't warranty there own work? Most offer a 12mo/12K warranty on work they have done. Who installed the head?
Old Nov 14, 2006 | 06:31 AM
vtec9's Avatar
Unless the tech at the honda dealer is a complete idiot, nothing he would have done while adjusting the valves would cause you to drop one. More plausible that it was an err of the machine shop.
Old Nov 14, 2006 | 07:43 AM
Ek9's Avatar
Ek9
Banned
The question is, did Honda send the head out to the machine shop or did you? If Honda did it then I think Honda owes you a motor. If you sent the head out then I think you might be screwed. I'd go back to the machine shop. You bent valves from an over-rev right? I wonder if the machine shop replaced the retainers or used the old ones? If they used the old ones, I'd say one of them failed.
Old Nov 14, 2006 | 09:38 PM
Artisan7471's Avatar
Most likely the machine shop reused the cracked retainers. I
Old Nov 15, 2006 | 05:02 AM
Ek9's Avatar
Ek9
Banned
I was thinking that too.
Old Nov 15, 2006 | 05:04 AM
Squeezer's Avatar
[QUOTE=Artisan7471,Nov 15 2006, 12:38 AM] Most likely the machine shop reused the cracked retainers. I
Old Nov 15, 2006 | 03:14 PM
s2kgash's Avatar
dammm thanks guys for all ur help, this truly sucks
Old Nov 15, 2006 | 05:24 PM
jeggy's Avatar
so did they replace ALL the valves along with some machine work? if they did then they should have at least seen cracked retainers during the removal/install. the machine shop may not know how to spot a cracked retainer while it is still on the head. but if they were in possesion of a cylinder head sent to them by a dealer, it must be undergoing some major work. in that case EVERY single part of that valvetrain should have been broken down to it's individual parts and inspected. and in doing so the machinist would have spotter a cracked retainer.
i dont see any reason why the dealer sent the head out just to replace a few bent valves, leaving other still in the head. if that was the case, then i ask this; why couldnt the dealer technician replace the valves himself instead of sending it out to a machine shop? was that tech not qualified to replace valves? yet he was allowed to remove the head?
Silver_Bullet_S
Oct 6, 2018 01:15 AM
gaxiola805
Apr 15, 2016 02:58 PM
cmc600rr
Nov 17, 2015 04:11 AM
the fan
Jun 18, 2009 08:04 PM
DezodWest_S2k
Jul 11, 2008 06:20 PM
