BRAKE light is stuck On...
Another way to fix it is to replace the plastic reservoir. You can't buy these from Honda but you can easily locate a replacement from someone who has replaced their entire mastercylinder. One screw and it pops off.
Ok I got the strainer off - wow, I feel dumb. It was obvious, I thought the tiny strainer came out, not the entire plastic rubbery piece.
Now my next question - I reached down in there.. I didn't feel any "float" object. Just the reservoir itself and some other hard pieces.
What exactly am I looking for.. nothing was able to move. I figured the float was movable.
Thanks again
Thanks again
Ok I figured it out after re-reading the posts.
There's a little vertical open ended channel in there.
And a cheap looking foam piece you can push down. It doesn't take much to get stuck. I used a small screw driver and pushed around till it moved freely.
No light! Thank you guys!!
TwiztedS2K
Sep 20, 2004 02:06 PM
