Brake overheating ?
Old Apr 28, 2010 | 03:44 AM
s2k dre's Avatar
Break them in, do get the new pads too hot.
Old Apr 28, 2010 | 05:06 AM
zeroptzero's Avatar
Originally Posted by slalom44,Apr 27 2010, 08:49 PM
A stuck pin would cause the problem you describe. I suggest you take it apart and find out why it's sticking. Sometimes it gets corroded in there, causing it to stick. If that's the problem, you could probably get away with cleaning it up with steel wool or emery cloth.
That is your problem. You should lubricate the pins on a regular basis on all four corners to avoid this problem in the future. I don't have a solution on getting the bad pin out, but don't drive with it like that, and make arrangements to lube the other pins before they end up like that - 2 pins per caliper.
jojipoji
Jun 27, 2011 09:42 AM
s2ook
Oct 25, 2008 04:47 PM
jah
Dec 16, 2005 06:20 AM
FULLTHROTTLE
Jul 4, 2002 07:38 AM
