Brake pad change help
Old Jun 26, 2011 | 06:17 PM
jojipoji's Avatar
Default Brake pad change help
I have changed my pads before on the s2k. However this time the piston on the brake was really hard to turn even using a die tool. Even when I did turn it down it didn't go in all the way. I sort of jammed the caliper on and when I drove it down the street and the brake was engaging when driving causing the brake to be really hard. Does this mean the caliper needs to be rebuilt? Any suggestions?
*yes parking brake was off*
Old Jun 26, 2011 | 06:51 PM
SgtB's Avatar
Was the park brake off?
Old Jun 26, 2011 | 08:17 PM
jojipoji's Avatar
yes it was. i got the other rear fine but just not the drivers side rear.
Old Jun 26, 2011 | 08:47 PM
brax_1's Avatar
I have the same problem!
I can 't seem to fit new pads on my driver side rear caliper, but everywhere else it's easy.
So annoying!
Old Jun 27, 2011 | 02:08 AM
s2cho's Avatar
maybe its time to flush out the break fuild? but i dunno.
Its a start
Old Jun 27, 2011 | 04:12 AM
jojipoji's Avatar
Nm Did a search looks like caliper piston needs rebuilding
Old Jun 27, 2011 | 09:42 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Originally Posted by hecash
If your brake fluid is not flushed on some sort of schedule, you can accumulate moisture and cause rusting inside a caliper. Being somewhat particular about brakes since they are the only element that stops the car, I'd recommend swapping in new calipers. I don't rebuild any more. It costs about $120 per side to replace the calipers with re-manufactured parts. That's what I's do.
AP2 Rear Brakes from Bill Kay Honda
I cant add anything else ^
drhess06259
Apr 28, 2010 05:06 AM
Hollywood Wheels
Aug 6, 2009 01:47 AM
Wombo
Jun 1, 2009 02:40 AM
jah
Dec 16, 2005 06:20 AM
Chris S
13
Sep 20, 2002 05:01 AM
