Carbon Fiber Mirror Install?
Old May 11, 2007 | 07:22 AM
UMDSuzuka's Avatar
Default Carbon Fiber Mirror Install?
I've been searching (so for unsuccesfully ) for a guide on how to remove the entire side mirror assembly to install aftermarker CF mirrors. Is it necessary to take off the door panels? I'm betting it is.
Old May 11, 2007 | 07:50 AM
minitoyota's Avatar
https://www.s2ki.com/forums/index.php?showtopic=158388
Old May 11, 2007 | 07:58 AM
Doug1627's Avatar
I would put money on it
Old May 11, 2007 | 08:20 AM
Stratocaster's Avatar
Yes, it sure is. There are bolts holding them on and you get to them from inside the door.
Good luck
Old May 11, 2007 | 08:30 AM
s2kshift9k's Avatar
yep you sure do it should take about 2 hours for the complete install or hour and half depending how fast you work!
Old May 11, 2007 | 01:40 PM
neveronlines2k's Avatar
1st door took about an hour 2nd door 30min. If you have some one hold the mirrors in place it will go much faster. Doing it by yourself is a pain, but I am too impatient
You will need to roll the window down about half way and take the door panels off. I saw a thread on here that said the windows needed to be removed, but it was not necessary for me (I have skinny arms though )
Old May 11, 2007 | 02:40 PM
blackout's Avatar
Anyone ever install CF doors? Im looking at taking everything out of my door and putting it into the CF door with some CF mirror. Anyone ever do this? or know of a write up on it? I want to make sure i do it in the right order. Also wanted to know if you could remove the side impact beams from the stock doors. It appears in the Shop manual that they can but obviously havent seen this for myself yet. Sorry to thread but you found your answer so
Old May 11, 2007 | 06:02 PM
UMDSuzuka's Avatar
Thanks all.
KoketsuCivicSi
Dec 18, 2016 05:11 PM
prodriverex
Mar 2, 2008 05:16 AM
jdmbm
Feb 29, 2008 01:57 PM
s2000_19
Jun 8, 2005 09:43 AM
TunedS2000
Dec 31, 2004 08:32 AM
