CEL code P0123 Top Dead Center Position 1 Sensor
Old Oct 20, 2013 | 10:06 AM
Deano_d's Avatar
Default CEL code P0123 Top Dead Center Position 1 Sensor
Hello all. I have an 02 S2000 completely stock with 70k miles on it. I have not driven it in over a week. Today when I started it up it ran really rough and a blinking cel came on. I immediately shut it down and used the modifry method of jumping the port off to get 8 fast blinks. I watched 4 times to be sure it was the only code. I swapped ignition coils from cyl 1 and 4, no dice. I swapped tdc sensors and no dice. I am thinking of buying a new TDC sensor from Honda tommorow. Anyone have experience with this?
Old Oct 21, 2013 | 02:08 PM
Deano_d's Avatar
Ordered some spark plugs and a tdc sensor today. OEM of course.
Old Oct 25, 2013 | 03:41 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Scan the car for the proper code.
Blink codes are limited access.
TDC sensor will likely not help.
Old Oct 25, 2013 | 04:35 AM
freq's Avatar
Listen to Billman.
Stop throwing $$$ away and wasting time. Get a scanner and do it right.
Old Oct 25, 2013 | 04:54 AM
MR.T's Avatar
X3. Scanners are as cheap as 20$ and one of the best tools you can buy for modern cars.
Old Oct 25, 2013 | 07:32 PM
Deano_d's Avatar
Using a friends scan gauge 2 tomorrow. Will report back.
Old Oct 31, 2013 | 08:52 AM
Deano_d's Avatar
Finally scanned it.
P0301 - cylinder 1 misfire detected
Old Oct 31, 2013 | 09:56 AM
Deano_d's Avatar
Update, moved the the #1 coil pack to #4 and got p0304. Looking like a bad coil pack. I need to invest in a obd2 scanner...
Old Nov 1, 2013 | 07:56 AM
Billman250's Avatar
Top Answer: 1
Now you are on the right track.
s2k_4life
Apr 6, 2012 10:53 AM
Lunacy
Jul 15, 2011 08:39 AM
sybar
Oct 27, 2010 01:03 PM
JS2k.com
Oct 7, 2007 09:27 PM
