CEL Light
Old Aug 10, 2011 | 03:34 PM
mmmgas's Avatar
Default CEL Light
Hello, I don't know if this is the right place but there was a post about the check engine light in here... Mine came on this morning and I suspect it is because I made a noob mistake and put lower octane instead of high (habitual). When I took the car to Advanced they tried plugging into the car, but he said it wasn't getting any power and that a fuse must be blown. I checked just about all of them in the parking lot and didn't see any evidence of a bad fuse. About half a tank of the low octane fuel was used so I filled up with premium today. Has anyone had a similar experience with the gas or with Advanced? I'm not sure he knew what he was doing- he said he hadn't done this with an S2000 before. Thanks!
Old Aug 11, 2011 | 06:26 AM
Reckon's Avatar
Take it to another place to have the OBDII read. Not sure what fuse would have been blown and you not realize it somehow. Any performance issues or noises?
Old Aug 11, 2011 | 07:08 AM
takeshi's Avatar
Pull the code before you assume it's related to lower octane fuel.
Old Aug 11, 2011 | 09:09 AM
s2cho's Avatar
go to auto zone and pull the code its free and they will tell you whats wrong.
Old Aug 11, 2011 | 08:43 PM
mmm...vtec's Avatar
If ur fuse wasnt blown you should start looking at the ground side of the OBD port...
Old Aug 12, 2011 | 04:46 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
You most likely have a bad fuse somewhere, in addition to a code.
The car powers the scan tool.
Old Aug 12, 2011 | 07:43 AM
mmmgas's Avatar
Well, the light went away after a few miles of premium fuel- but I'm still taking it to another place for a scan. I re-checked the fuses and none of them are blown. The ACC works fine. Nothing noticeable either.... no issues thus far.
Buntinboy9
Oct 23, 2015 05:01 PM
PatentedS2k
Mar 31, 2014 01:57 PM
ChineseDelivery
Aug 11, 2010 01:47 PM
GoFaassttt
Feb 21, 2008 09:12 AM
JPNSPEC
Feb 2, 2006 07:19 AM
