Changed the oil
Old Dec 14, 2011 | 02:19 PM
Troystaten's Avatar
Default Changed the oil
Changed the engine oil, the diff oil and the transmission oil today. This is the first time I have done this on this car myself (I have changed the oil on many other cars and trucks before) I did not have a floor jack or 4 jack stands so I had not done this work myself on this car. A friend of mine brought his over today and we did it fairly quickly. I was pleased that after 5000 miles the car had not used any oil that I could measure, I guess this should not superise my as my 99 Honda Odyssey has 135,000 and it does not use any oil either Honda sure makes a nice engine. Last time I used Mobil 1 extended. This time Castrol synthetic Edge. Love the car.
Old Dec 14, 2011 | 04:33 PM
s2000maniac's Avatar
Old Dec 14, 2011 | 05:47 PM
importkid's Avatar
Should be in s2000 talk, but glad you didn't have any problems with your maintenance of the car. This car is surprisingly easy to work on, proving it is still a Honda.
Old Dec 14, 2011 | 08:41 PM
Troystaten's Avatar
Sorry for posting in the wrong section.
Old Dec 15, 2011 | 09:36 AM
grkboy707's Avatar
Its all good. Want the oil change even easier? I plan on getting a Fumoto drain valve. Put it in place of your drain plug, and you dont even need to jack your car up for an oil change.
Old Dec 15, 2011 | 09:39 AM
Troystaten's Avatar
Being the paranoid type I always worry about anything different when it comes to oil drain plugs but I will check it out.
Thanks
Old Dec 15, 2011 | 10:01 AM
tantheman's Avatar
"I was pleased that after 5000 miles the car had not used any oil that I could measure", did you mean it did not burn oil? After 58,000 miles and checking oil levels at every fuel fill up, I have never had any oil issues too.
Tan
Old Dec 16, 2011 | 08:31 PM
Troystaten's Avatar
Tan
Correct it did not appear to use any oil. I checked the dipstick regularly from the start of the last oil change and the one I just did and the oil level had not moved at all. Not the most scientific but this car is sure a lot better than my wife's 2000 Passat.
PStanger
Sep 8, 2009 07:58 PM
jdmgpw04
Oct 23, 2006 12:17 PM
soundzero
Nov 3, 2003 07:54 AM
Steve2K
Oct 30, 2002 03:32 PM
GundamZ
Aug 7, 2002 12:17 AM
