Changing Primary O2 Sensor on Header: How-To Help?
Old Mar 31, 2025 | 01:24 PM
  #21
B serious's Avatar
Originally Posted by Dibsen
why is that?
I’ve been having some fuel problems causing the car to lose power and “stumble” on occasion. Trouble shooting lead me here. So far, seems to have fixed the issue
I've never had an non OE sensor work well for any appreciable amount of time, is why I say the Bosch won't work.
You should go with Denso or NTK sensors.
As far as fixing your issue with the car stumbling on heavy acceleration...it would be strange for an O2 sensor to affect that. The car goes into open loop after a certain throttle percentage.
Your narrow band O2 sensors aren't a primary source of information for fueling when in open loop. That's almost all done via speed/density data (TPS, MAP, IAT, and Knock).
The ECU largely/fully ignores the O2 sensor during open loop. Even an unplugged narrow band O2 sensor shouldn't cause issues in open loop.
But if whatever you did is working then let it work!
Old Apr 1, 2025 | 04:05 PM
  #22
Dibsen's Avatar
thanks B, if it comes back I’ll hit you up.
s2000maniac
Mar 29, 2025 09:09 AM
Subalahoo
Apr 6, 2009 02:48 PM
jah
Sep 23, 2007 06:26 PM
bulldogs2k
Oct 19, 2006 12:20 PM
thetz99
Nov 21, 2005 04:16 AM
