chasing this high idle!! help!
Old Nov 21, 2022 | 01:37 PM
yamaha6611's Avatar
Default chasing this high idle!! help!
cant get an idle under 2,000 rpm, even when warm. heres what ive tried...
tried:
deep clean IACV
smoke test intake mani @ TDC (tiny bit of smoke came out of the throttle body screw but i highly doubt that could cause this?)
adjusted throttle screw all the way back
took throttle cable off and checked idle, still 2k rpm
to do:
try additional IACV
check tune (AEM V2)
car was recently tuned by jeff evans, so i highly doubt were looking at a tuning issue. what im wondering now...
- is the IACV adjustable like a TPS? when the screws are loose it does have a little bit of back and fourth play
-could it be the TPS? its got the factory rivets
-AEM serial gauge reads 2.75% at idle and 99.2% at WOT, jeff said this is normal and that it is certainly a vacuum leak.
- jeff also said that you cant re learn the idle because its not a factory ECU... so thats out.
any help is greatly appreciated!
Old Dec 12, 2022 | 05:39 PM
dreis2k's Avatar
Does the RPMs bounce during idle?
ryiin2
May 21, 2018 12:36 PM
snitm
Dec 28, 2015 01:58 PM
bio
Aug 8, 2013 03:59 PM
s2kseven
Sep 16, 2012 08:02 AM
pedrobaby77
Jul 14, 2010 05:59 PM
