Check engine light question...
Old Aug 31, 2005 | 10:27 AM
blackfx35's Avatar
Default Check engine light question...
When I turn my key to on position the check engine light stays on and it blinks 5 times before it goes off...is this normal?
I scanned the ecu and there is no error code...what can it be?
I'm asking because I had a cel light for o2 heater wire after installing the wideband...the cel is gone but now it blinks before it goes off...I don't know if this is normal because I really didn't pay attention to the light before...
Old Aug 31, 2005 | 10:36 AM
xviper's Avatar
Are you sure it's not the "MAINT REQUIR'D" light?
Old Aug 31, 2005 | 11:03 AM
SIIK2NR's Avatar
If you reset the ECU then the blinking CEL is normal. It states in the manual that it will blink for a while (can't remember how long) as it resets it's self..
Read the manual......it's in there...
Old Aug 31, 2005 | 11:41 AM
blackfx35's Avatar
Thanks once again...
Old Aug 31, 2005 | 11:57 AM
xviper's Avatar
I wonder if this is a new feature of the AP2? I've reset my ECU plenty of times (as experiments) using both the BACK UP fuse method and the OBD II scanner method and the light has never blinked afterwards.
Old Aug 31, 2005 | 12:03 PM
SIIK2NR's Avatar
It states in the manual something about the blinking and shutting off or blinking and staying on...
There is also a blurb on the gas cap issue and the CEL taking time to reset.
I'll pull up the manual and post it later...
I'm not sure if it's AP2 specific....but I remember this specific question in my own mind when I was troubleshooting a CEL after my SC install...
Old Aug 31, 2005 | 04:57 PM
SIIK2NR's Avatar
[QUOTE=xviper,Aug 31 2005, 11:57 AM] I wonder if this is a new feature of the AP2?
Artric
Aug 19, 2016 01:18 AM
Wayners
Nov 1, 2010 03:45 AM
Ogre
Oct 21, 2005 10:48 AM
JimmyB
Apr 19, 2005 03:48 PM
2Ting
Oct 26, 2002 07:01 AM
