Clutch differences
Old Apr 3, 2010 | 10:12 AM
coursevector's Avatar
Default Clutch differences
I recently test drove a 2005 and the clutch feels very very "light"?
Is there a big difference between 01 and 05 clutch feel?
I've daily driven a 2001 S2000 for 5 years and felt a small difference over time
I would say my 01 is around a 5
For reference I consider my old 1987 bmw 325 with a slipping clutch a 1
and would consider my friends race clutch a 10
The 05 clutch feels somewhere around a 3 in pressure required and had very slight slipping.
Is it normal for a 05 clutch to feel this light?
Were there any changes made since 01 to make the 05 feel this different?
If there is something wrong with it will having a Honda dealer check it out reveal anything? Not sure if there is a way to check anything clutch related without tearing it apart.
Thanks
Old Apr 3, 2010 | 01:31 PM
dammitjim's Avatar
Define "light". It's normal for a slipping clutch to slip. If it's slipping it probably needs replacing.
Old Apr 8, 2010 | 01:20 PM
I would say it took about half the pressure of my '01.
So if my 01 takes 50lbs of pressure to depress the clutch I would say this takes 25lbs.
Does that make sense?
Old Apr 9, 2010 | 09:19 AM
INTJ's Avatar
My guess would be the lube on the system (hat splines, etc). Several people have noted that a re-greased same kit was a lot lighter clutch. Its really the let off engagement point that tells me something is worn short of real slipping. The higher the engagement, the worse it is.
Green Tea
Aug 13, 2010 03:28 PM
Scot
Jan 13, 2010 11:45 PM
SilverS2kF22C1
Aug 11, 2009 10:05 AM
Bat
May 4, 2006 08:00 PM
TwistedS2k
Oct 11, 2004 11:05 AM
