clutch help
Old Jun 8, 2013 | 02:07 PM
jjaypal's Avatar
Default clutch help
i posted on here a bit ago about my clutch starting to give out. its not clutch fluid nothing leaks. i took it to a family friend who has a shop and he said i might have 4-6 months left of the clutch. the part is $850 but he will only charge me $600 (his cost). the clutch hes getting is just from the auto parts store. does anyone know of a better clutch for same or cheaper price. i get install for free. THANKS.
Old Jun 8, 2013 | 02:44 PM
s2cho's Avatar
oem clutch should only be around 200 dollars and theres no way parts are 850 even if you swap out bearings with a new fly wheel and new pressure plate.
Old Jun 8, 2013 | 03:04 PM
jjaypal's Avatar
thanks! do you know where i can find an oem clutch?
Old Jun 8, 2013 | 03:37 PM
jjaypal's Avatar
any other recommendations on different clutches? maybe better performance clutch for around same price?
Old Jun 8, 2013 | 03:49 PM
S2KIrishman's Avatar
oem disc with an ACT pressure plate and then oem bearings...id get the flywheel resurfaced too
Old Jun 8, 2013 | 10:38 PM
s2cho's Avatar
http://www.hondaautomotiveparts.com/
I find its usually a good price, and for stock power anything above oem is just overkill. the stock clutch is great and can even handle power on a sc s2k.
Old Jun 9, 2013 | 04:09 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
DO NOT use any other disc but one right from Honda.
There is no part that costs 850.
Disc and two bearings is 250 right from honda, do not use that auto parts store crap.
Old Jun 9, 2013 | 04:21 AM
s2000maniac's Avatar
about how many times can the flywheel be resurfaced?
Old Jun 9, 2013 | 06:06 AM
jjaypal's Avatar
Do I need the whole clutch kit from Honda or just certain parts?
Old Jun 10, 2013 | 01:40 PM
s2cho's Avatar
Depends whats wrong with the trans, if its slipping I would just replace the clutch, bearings, and get the flywheel resurfaced. If there is something else wrong with the trans, your going to have to rip it apart and go from there. I honestly think your family friend doesn't know what he is talking about and trying to make some money off you. 850 for a clutch parts is ridiculous, and even his price of 600. Locally I can get my clutch replaced for about 800 with labor and parts.
wankun
Oct 26, 2016 01:18 PM
tx2K
Dec 24, 2013 08:30 AM
prj3ctm4yh3m
Jun 26, 2011 12:59 PM
oyitzpreston
25
Aug 7, 2009 06:01 PM
robinson
Aug 30, 2006 07:08 PM
