Clutch Interlock Bypass with E-Brake
Old Mar 22, 2018 | 01:30 PM
Bugsy's Avatar
Default Clutch Interlock Bypass with E-Brake
Clutch interlock works normal but you may start it with E-Brake on...
Old Mar 22, 2018 | 02:00 PM
noodels's Avatar
That should save some crank thrust washer wear,
be a nice idea to have a prime function to get oil pressure before it engine starts !
Old Mar 23, 2018 | 03:49 AM
Car Analogy's Avatar
Excellent mod.
But, a potential flaw. If the parking brake is only partially engaged, and someone accidentally starts the car in gear, it can still take off. What will that person do? Hopefully they can take an intelligent, non panicked action before anything bad happens.
If you use the brake pedal instead of parking brake, same scenario, pedal only partially engaged, car begins to roll, most anyone's natural reaction is going to be press pedal harder. Crisis averted.
Old Mar 23, 2018 | 05:25 AM
Bugsy's Avatar
Originally Posted by Car Analogy
Excellent mod.
I agree with you. It's not perfect, but it's perfect for me.
In Europe, they don't even have the interlock... it's still there for the next owner, but it can be circumnavigated. I rarely ever had need to use the parking brake, except to lower the convertible top when I was moving slowly as I've isolated the speed sensor wire to the top control.
On a side note, if I ever ran out of gas on railroad tracks, I could use the starter to move me off them LOL !
Old Mar 23, 2018 | 06:05 AM
Afterfire's Avatar
Very nice. Id love to do this. When I tried to redo my cruise control to take the place of my roof switch I ran into the issue of how was I going to pass the wires from the center console area to the under steering wheel dash area so I just chose to relocate the whole switch to right under the dash. Is there a tunnel or passage under the leather cover or something? How are you going to route it?
Old Mar 23, 2018 | 06:14 AM
Bugsy's Avatar
It was just the one light blue wire.
I used an aluminum welding rod (coat hanger like) and rounded the end over so as not to snag anything. Pushed it through between the tunnel and the fabric from near the OBD port to the center console recess, then hooked on to the rod and pulled the electrical wire through. I wouldn't want to pull too much trough there. One wire was fine. A bundle and I'd try to do something else which would require dash / console / radio bezel box removal to gain access...
lowS2k
Mar 6, 2016 05:38 AM
Kobeirving
Sep 10, 2013 08:49 PM
lower
Car Talk - Non S2000
30
Nov 23, 2007 11:45 AM
jg95672
Jun 8, 2005 03:19 PM
nwk00
May 30, 2003 11:11 AM
