Comptech CAI Install
Old Oct 14, 2005 | 10:21 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you lug the engine below vtec in higher gears, you'll get a nasty vibrating sound. most likely the lid, it's normal.
Old Oct 14, 2005 | 10:46 AM
Ubetit's Avatar
Originally Posted by billman250,Oct 14 2005, 10:36 AM
Lemme give you guys a tip, not in the instructions:
On the rear mounting tab, there's a wiring harness that runs over it. Remove the stock tab, move the harness under the tab, and re-install.
Box will fit perfectly everytime...I've got about 7 or 8 under my belt.
No need to drill the box, ever.
This intake requires a little out of the box thinking, it is NOT your typical bolt on. It is an absolute perfect fit.
If the search was working I could point you to my thread that already has this documented.
Here it is:
https://www.s2ki.com/forums/index.ph...pic=292613&hl=
lvd1102
Mar 28, 2010 09:44 AM
vstypicals
Sep 1, 2009 04:37 AM
kctham
Mar 17, 2005 05:15 AM
douge
Apr 12, 2004 04:32 PM
krazik
Nov 21, 2003 11:17 AM
