Comptech S/C oil return line?
Old Aug 2, 2004 | 07:11 PM
KenGPW's Avatar
Default Comptech S/C oil return line?
I got my kit but the part that threads into the oil pan is too big...... There is a piece that threads into the line itself but the one end is too big to fit the drain bolt. Anyone know if Im missing a piece or if I can get a new one????? Where can I get it/ or what do I need?????
Thanks Kenny
Sorry for all the posts/questions
Old Aug 2, 2004 | 09:37 PM
Ludedude's Avatar
Administrator
I'm pretty sure you have to drill a hole and tap new threads into the pan for the return line, it doesn't thread into where the oil drain bolt goes. Think about it...how would you drain the oil when it was time to change it then?
Maybe I'm misunderstanding your question?
Old Aug 3, 2004 | 02:29 AM
Asura's Avatar
You do not tap a hole with the Comptech kit. Vortech yes.
The Comptech comes with an adapter that screws in to the drain hole. The AN hose screws on to this, not directly to the pan.
You need an AN fitted adapter than is threaded like the drain bolt on one side and mates to the AN fitting on the hose. You can order this from Earl's or just contact Comptech directly and ask them to overnight you one.
Old Aug 3, 2004 | 02:42 AM
swtazn97's Avatar
Asura's right. Just go to any speedshop place and ask for aeroquip or earl's fittings. They're blue and look nice too.
You can call up comptech, or look up size fitting on the instructions, then order the part through summitracing website
Old Aug 3, 2004 | 03:45 AM
SanMarinoCpe's Avatar
This might help
Step #9: Blower Oil lines:
Old Aug 3, 2004 | 10:08 AM
Ludedude's Avatar
Administrator
I stand corrected then. I was mixing up Comptech and Vortech installations.
jit13
May 13, 2011 05:43 AM
JDM S2000
Dec 3, 2006 09:50 AM
mwd473
Oct 1, 2006 06:03 PM
r_duff
Sep 7, 2005 02:06 PM
jdmdohcpower
Oct 31, 2004 04:45 PM
