Consequence of driving with low oil level
Old May 23, 2002 | 08:03 PM
Cyberorth's Avatar
Default Consequence of driving with low oil level
I kept checking the oil for awhile and it looked like there was no oil burning, so I stopped checking.
Then after about a month I checked again yesterday and ...
There was only about 1/4 inch oil from the end of the stick, below "L."
I added today. The oil light never came on and I never had any problem with the VTEC not switching.
Do I need to worry about anything?
Old May 24, 2002 | 04:20 AM
John MI blk/blk '01's Avatar
As long as you didn't vtec you shouldn't have a problem. If you vtec'd then you are SOL. You should probably sell it to an unsuspecting fool. No, just kidding. Should be no problem. Just be sure to check it more often. I have 12,250 miles and my car needs to be topped off. I still use about a half quart every 2000 miles. When I was breaking the car in, I used as much as a quart every 1000 miles.
John
Old May 26, 2002 | 06:38 PM
Cyberorth's Avatar
Thanx!
I think I need to go buy a funnel because I already made a mess trying to put oil in. The dipstick is a pain in the ass btw. Never had such a hard time reading the oil level before this car.
Old May 26, 2002 | 08:26 PM
Utah S2K's Avatar
[QUOTE]Originally posted by John MI blk/blk '01
[B]As long as you didn't vtec you shouldn't have a problem.
Old May 26, 2002 | 10:21 PM
Cyberorth's Avatar
The question with the member at hand... I mean the member with the question at hand would like to thank the corresponding moderator for his/her advice.
Old May 27, 2002 | 07:25 AM
Cyberorth,
The dipstick is a PITA to read correctly. Just make sure you're on a level surface and read from the side that shows the lowest level. ALso, good idea to invest in a funnel. I spilled too. What happens is that the oil will run along the inside of the valve cover valley.
Utah s2k,
I am glad someone has a sense of humor.
John
Old May 28, 2002 | 12:06 AM
mynameisneo's Avatar
What could be done to see if any damage was created? Leak-down test? Oil analisys? Dyno?
Old May 28, 2002 | 09:30 PM
Utah S2K's Avatar
If you really are anal about the car (as I am) you could send a sample to Blackstone for analysis (www.blackstone-labs.com). Ryan has a pretty good baseline on Honda break in oil for this car. The first thing to go would be viscosity if the oil were really fried. He can also do a hard particle count (baseline for this car established on that too). Anyway once again my opionion is just swap it out and keep a better eye on it in the future....
Utah
P.S. Mention your a member of S2Ki and he'll give you a club price (about 18 bucks I think). Tell him Utah sent ya......
AdrianG
Sep 20, 2008 05:23 PM
js2k24
South Florida
Dec 1, 2004 03:27 AM
thereisnospoon
Jul 28, 2003 08:38 PM
pjkwong
May 7, 2003 02:45 PM
Eze8199
Mar 20, 2003 05:19 AM
