Convertible joints need oiling?
Old Mar 23, 2011 | 05:27 PM
Carbon Blue's Avatar
Default Convertible joints need oiling?
Hey there, just wondering if the rotating joints in the soft top frame need to be oiled? There seems to be a slight noise coming from the top when putting it up or down. I was thinking the joints might need to be oiled, if so what do you guys use?
Old Mar 23, 2011 | 06:16 PM
zeroptzero's Avatar
I sprayed mine, I used a penetrating rust proofing spray as it seeps into tight crevices, pretty much any lubricating or oil like product can be used which can penetrate tight spaces. Just be sure to clean up the overspray as it doesn't take much for each hinge.
Old Mar 23, 2011 | 10:50 PM
dirtykoala's Avatar
maybe use some lithium grease?
Old Mar 24, 2011 | 05:05 AM
zeroptzero's Avatar
yeah one of the convertible top TSB's from Honda calls for lithium grease to be used on those areas to reduce noise,I did try it once but I found it hard to get the grease into the tight areas even using a spray type lithium grease, then I tried a penetrating rustproofing spray. I see some rust developing on some of the hinges at times so I thought it would be worth using.
Old Mar 24, 2011 | 09:45 AM
robmea's Avatar
Ive been wondering the same thing! I was thinking maby some silicone grease type lube? like the stuff for the window tracks. I know its not messy and doesnt really leave any residue. Think im gonna try that for all the joints, and then some lithium for the actual gears on each side where the motor or motors? are on each side.
Old Mar 24, 2011 | 10:14 AM
hirev's Avatar
I shoot some wd 40 into the joints now and then when i remember, this is a noisy car.
Old Mar 26, 2011 | 08:28 PM
Bror Jace's Avatar
WD-40 is a poor lubricant. It was meant as a water displacer (hence the "WD") and only has light lubricating properties.
I think I will try some Valvoline spray lube when I get the car out in another week or two.
http://www.theautochannel.com/news/2...30/009572.html
The spray-anyway nozzle and straw should help.
Old Mar 28, 2011 | 11:33 AM
arkkornkid's Avatar
try this stuff, you won't be disappointed.... you can find it at Home Depot:
Old Mar 28, 2011 | 02:47 PM
SgtB's Avatar
Spray Teflon or spray lithium. Goes on runny, and gels into grease.
instinct
Jul 19, 2014 06:00 AM
smach
Jun 8, 2010 09:04 AM
Wobbly
Dec 6, 2008 12:26 PM
inactiveuser1114
Nov 28, 2006 09:04 AM
ivass
Jun 26, 2005 08:53 PM
