COnverting a UK engine to JDM
Old Jun 20, 2005 | 10:32 AM
little Chris's Avatar
Default COnverting a UK engine to JDM
Just sold my JDM but will be getting another S in the future.
Will most likely be getting a UK car but I know there are some differences in the Engine over the JDM. The JDM BHP is about 247BHP but the UK is 237. I belive the difference is down to the 100RON octane fuel available in Japan and that the head gaskget is different. Can any one tell me all the differences, how easy it would be to convert the UK engine to JDM and is it really worth it?
As the S can be sooooooo exspensive to modify is this going to be the most cost effective mod I could do?
I'm not a BIG engine junky so go easy on the Jargon please
Thanks lads and ladets
Chris
Old Jun 20, 2005 | 01:26 PM
MaxGeek's Avatar
I don't think its worth it, but I believe you can buy a spoon (or another JDM brand) head gasket that will increase the compression ratio. It does require/recommend higher octane.
Old Jun 21, 2005 | 05:52 AM
AndyDoh's Avatar
I've heard this loads of times and I'm not sure what it is, I would suspect that it is just the ECU that gives the extra power!? but other people have said its the pistons then others have said the gasket.... it gets confusing after a bit!?!
Old Jun 21, 2005 | 09:13 AM
michael ferguson's Avatar
Its usually the gasket etc for running higher octane from JDM imports that cause the most of the difference, but it can also be down to the emission levels on the UK cars, imports don't have as strict emissions to pass and so they have different cats, which reduce back pressure etc. You can easily get round this by putting on a full system.
Old Jun 22, 2005 | 01:36 AM
So,
Looks like a Mugen ECU, HG and new exhaust (possibly just de-cat) would be the way to go. Would any one disagree, and why?
How difficult is it to change a Head gaskget?
Old Jun 22, 2005 | 05:38 AM
steven975's Avatar
^ changing the head gasket is very time consuming.
i wouldn't do it by yourself. You'll need a helper to pull the head; the aluminum is soft so you don't want to damage anything in your attempts to remove it. It requires a good bit of work, but it really is mostly undoing bolts and what-not.
Putting it back on requires a lot of precision. You'll need a torque wrench; follow the specs religiously. I've never done a S2000 gasket change, but I've done it on others.
Old Jun 22, 2005 | 06:04 AM
S2000_Europe's Avatar
the best mod for the $ are gears, go for a shorter ratio like 4.44 or 4.65
Stocky @ the european forum sell it
Juan
Ek_Jak
Dec 12, 2014 10:09 AM
Russ_16v
Jan 4, 2013 01:00 PM
loftust
Mar 18, 2012 01:11 AM
motoracer90
Aug 7, 2011 06:23 PM
Cheese and Onion
Apr 28, 2009 05:49 PM
