Correct timing
Old Jul 7, 2018 | 12:15 PM
Zack Atkinson's Avatar
Default Correct timing
How to put my cam shaft And crankshaft in (tdc) correct timing. My s2k won’t start and I think it needs to be put In correct timing. Thanks.
Old Jul 7, 2018 | 01:21 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Was the engine taken apart recently, and hasn’t ran since?
Old Jul 7, 2018 | 01:59 PM
Yeah
Old Jul 8, 2018 | 07:28 AM
yes when I bought it from the previous owner it was a rebuilt title and he put a new motor in it and did everything but couldn’t get it started and said it was the timing needed to be corrected.
Old Jul 8, 2018 | 10:57 AM
Chuck S's Avatar
There's an illustration in the Service Manual. It's even on Page 6-12 of the manual commonly on line with the Japanese bikini model on the cover.
-- Chuck
Old Jul 8, 2018 | 10:59 AM
-- Chuck
the service manual for the car? I would have to look To see if I have that. I’d there anyway I could find that manual online?
Old Jul 8, 2018 | 11:34 AM
Originally Posted by Boosted04S2K
ok I see how would I turn the gears for the camshaft on the intake and exhaust clockwise or counterclockwise? And also how would I turn the gear for the camshaft? Using a wrench or some kind of special tool? Should I take out the spark plugs when I do this? Just wanna make sure the installation is done right. Also how would I test it to make sure its right besides trying to start it up? Thanks for the help
Old Jul 8, 2018 | 11:35 AM
I meant for the crankshaft*
Old Jul 8, 2018 | 12:12 PM
flanders's Avatar
19mm socket on the crank pulley and turn it clockwise, you don't need to remove the spark plugs but its much easier to turn the engine with them removed.
Old Jul 8, 2018 | 03:19 PM
I was able to adjust the timing from the crank but the timing is still off when it’s at tdc not sure what to do from here
