Correct timing
Old Jul 10, 2018 | 11:20 AM
  #41
starchland's Avatar
Maybe I missed it, but is it cranking?
Old Jul 10, 2018 | 11:24 AM
  #42
Boosted04S2K's Avatar
Originally Posted by s2000Junky
I agree they should be checked anyway as common practice considering the head was removed. But I would find this least likely the cause of the engine giving no signs of life. Worst case scenario the engine should at least give a sign of firing in one or a couple of cylinders even if all the valves were out of spec to large degree. Every cylinder would have to have valves be so tight that no valve was seating enough to develop any compression in the cylinder. I would be really surprised if that were the case.
Agreed.
Old Jul 10, 2018 | 02:42 PM
  #43
Slowcrash_101's Avatar
I apologize for posting that, I didn't see the timing gear was off.
If you do have to change the crank trigger wheel, don't you have to take off the crank pulley, the timing cover, and to do that don't you have to take off the oil pan(not exactly a quick repair)? We don't even know which crank angle sensor is on the car.
Old Jul 10, 2018 | 10:22 PM
  #44
flanders's Avatar
Originally Posted by Billman250
Check the engine serial, left front top corner of the block, see if its a 2.2L. Common swap as they are more plentiful.
If it is, and has the DBW trigger wheel, it will not run.
Also verify the green key light comes on when you turn the key on, then goes off.
Besides checking the above you could also check what kind of crank sensor you got installed.
Here is a picture of old vs new, the new one has the connector right at the sensor so should be easy to identify.
Old Nov 27, 2018 | 05:59 PM
  #45
Zack Atkinson's Avatar
Default *HELP* need a new engine
Need a new engine for my 2002 Honda S2000 ap1. Couldn’t make a post.
Old Nov 27, 2018 | 08:41 PM
  #46
noodels's Avatar
What was the problem ?
Old Nov 28, 2018 | 03:42 AM
  #47
summitrider2012's Avatar
if there is fuel getting to the cylinder I would think the imobi is fine. Sounds like a spark issue. Weather it’s there is no signal from the ckp/cmp or a fuse blown or something else is what I would be looking at.
  #48
did you get it? Why do you need a new motor?
scalpel
Oct 21, 2020 10:17 PM
ROB1980
Jan 6, 2019 05:42 AM
Mike in Detroit
Tampa
Jun 23, 2017 03:03 AM
