cv boot failure
Old Feb 11, 2014 | 06:51 PM
Germanturtle's Avatar
Default cv boot failure
recently discovered a pinhole leak in my rear cv boot and attempted to patch the hole. after a test ride i realized i had failed. so now i have searched and came with a few options - may i also ad the car isnt a track car or beat on -
spoon boots - ouch on cost and the companies i deal with dont stock them - so no go
buying a new axle from a honda source - even with discount ouch - no go again
buying a used axle from a junkyard - not sure how long it will hold up before needing repair to bearings/ internal parts - possible option - most affordable
buying aftermarket axles - not f.i. so my power levels dont really warrant investing in these i.m.h.o. - why??
ordering a new boot, reusing oem rings, buying the special tool for the rings, replacing the internal parts - best option?
looking for your opinions on the options, if i am not looking at something please inform me. i have no problem with doing my own work so please advise away, thanks in advance.
Old Feb 11, 2014 | 07:10 PM
DeeKay's Avatar
I think these are what you need
http://www.tooltopia.com/lisle-30800.aspx
I say replace the boot, new clamps, make sure it's greased, put it back together. If the internals aren't damaged and it was a very small leak, there's no reason to replace the internals.
Old Feb 11, 2014 | 07:38 PM
emdzey01's Avatar
Just buy a new boot. The oem clamps do not need any special tools aside from a nice sturdy pair of long nose pliers and a firm grip.
Old Feb 11, 2014 | 09:20 PM
realblag's Avatar
Just get a new OEM boot and some good grease. I wouldn't bother changing the internal components unless you damage them trying to get them off the axle. Good info here > https://www.s2ki.com/s2000/topic/106...-the-cv-axles/
Old Feb 12, 2014 | 03:22 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Take aftermarket axles off your list. Any other axle but a hollow shaft honda axle vibrate horribly right out of the box.
Do the boot.
kleecker
May 7, 2011 05:51 AM
CKit
May 15, 2009 05:53 AM
BananaYellow
Mar 15, 2004 03:16 PM
Dracoro
Nov 8, 2002 10:32 AM
Sideways
Apr 6, 2001 05:16 AM
