delete
Old Oct 28, 2013 | 08:10 PM
apme123's Avatar
Default delete
everything is cleared up
Old Oct 31, 2013 | 03:40 PM
apme123's Avatar
Bump
Old Oct 31, 2013 | 05:03 PM
S2KPUDDYDAD's Avatar
Originally Posted by apme123
my s2000 has developed a 1st and 2nd gear whine while accelerating or coasting with the clutch engaged and disengaged still in gear. what do I need to rebuild or replace? is it the tail shaft bearing?
Any whine in other gears or neutral, coasting?
Old Oct 31, 2013 | 06:18 PM
apme123's Avatar
Cleared up
Old Nov 1, 2013 | 04:22 AM
aeonracer's Avatar
I'd be willing to be you're hearing your diff and not your gears. Is it a steady increase in noise / pitch as you go faster? When was the last time you replaced your diff fluid?
Also keep in mind that this car makes noises. My diff whines a bit at low speeds in low gears when it's cold out. I religiously change my diff fluid, and do yearly checks on all the visible parts. None of my bearings look like they're failing nor do I have any transmission issues. It just makes noise...
Old Nov 1, 2013 | 01:14 PM
apme123's Avatar
cleared up, delete
Old Nov 1, 2013 | 06:59 PM
And it goes away, silent once you hit 3rd gear or higher? What if you short shift the car into 3rd gear a couple hundred rpm lower do you have any gear whine? Trying to see if it is speed or RPM related
Old Nov 2, 2013 | 08:35 AM
apme123's Avatar
problem resovled thx
Old Nov 2, 2013 | 01:26 PM
no whine in third or any higher gears just 1 and 2 unless it's at 1200rpm or something
Ok, so it is RPM related, 1200 RPM or less and you hear gear whine above 1,200 RPM and it goes away?
Old Nov 2, 2013 | 02:12 PM
apme123's Avatar
problem resolved thx
ravi1987
Jul 31, 2009 07:57 AM
TrackStar
Mar 23, 2007 08:06 AM
B.Money
Mar 17, 2007 01:26 PM
NightStalker
Oct 25, 2005 10:04 AM
mwy23
Jul 20, 2005 06:39 AM
