differential blown~!
Old Jan 9, 2011 | 10:42 AM
boxmetogo's Avatar
this DIY looks easy enough.
https://www.s2ki.com/forums/index.php?showt...&#entry16215953
Old Jan 9, 2011 | 10:59 AM
boxmetogo's Avatar
Sorry i just answered my own question. I just read Shocks DIY - https://www.s2ki.com/forums/index.php?showt...&#entry12226079
this is something i shoud leave to my mechanic to do. I Just dont have the correct tools.
Old Jan 9, 2011 | 11:03 AM
S2KPUDDYDAD's Avatar
Originally Posted by boxmetogo,Jan 9 2011, 02:42 PM
That DIY is just for the R&R not changing out the broke internals of your damaged rear.
I built the replacement rear for that DIY
With trade of you old damaged rear I send you a reconditioned rear ready to go for less than you can rebild your self.
I also helped shock with that build as well
If you chose to rebuild your self you can call me for instructions or advice. Good luck
Old Jan 9, 2011 | 12:11 PM
ans2k's Avatar
Puddydad is the man!!! His diffs are the best!!!
Old Jan 9, 2011 | 12:20 PM
INTJ's Avatar
Originally Posted by chris_barry,Jan 8 2011, 07:13 PM
Fit a Miata NB model crownwheel and pinion into your housing. I've found they are stronger than the Honda equivalent gears and bolt straight in.
Really? This is a huge solution. Has this been posted in detail somewhere and I missed it?
Old Jan 9, 2011 | 12:32 PM
The Miata 4.10 gear is the exact same as the one in the S2000 MH01-27-110
Old Jan 10, 2011 | 02:31 AM
deepbluejh's Avatar
Nothing against Puddy - I hear nothing but rave reviews about his work - but if you're running stock power and not beating on the car (racing, etc), then a stock replacement diff will be just fine for you.
Old Jan 10, 2011 | 03:30 AM
That is why I build a stock reconditioned rear for just a few bucks more than some used rear. If you trade in the blown rear it ends up being about the same price as used
Old Jan 10, 2011 | 08:00 AM
TougeS2k's Avatar
Thats what i'd do... because buying an as-is used diff could result in another blown diff incident in two weeks. If you dont have about $1000 for car issues you shouldn't drive an s2000.
Old Jan 10, 2011 | 08:48 AM
Saki GT's Avatar
Frankly, stock parts don't always hold up, which is why so many fail. I'm not sure stock is good enough if you ever plan to push it. I don't launch my car, but with even minimal hard starts on an auto-x course I expect mine to go someday.
