Differential Problem=(
Old May 9, 2007 | 11:10 AM
SpitfireS's Avatar
tekstar Posted on May 7 2007, 07:24 PM
I did buy the car used a little over 2 months ago so I have no idea how the previous owner handled the car.
Then you also don't know how it was serviced?
Change out the diff oil.
Look for larger shavings in the old oil AND on the magnetic drain plug.
You could take a look at the ring gear through the drain hole (watch for oil drops)
Use the recommended SAE 90 GL-5 oil for the diff.
LE-607 is a very good (the best ) choice.
1 quart will do.
Old Apr 28, 2008 | 07:10 AM
aladdin20110's Avatar
how often should we change out the diff oil?
Old Apr 29, 2008 | 02:50 PM
captain_pants's Avatar
Originally Posted by tekstar,May 7 2007, 12:24 PM
If your diff is broken, what kind of noise would it make? Is it loud?
Example: http://www.youtube.com/watch?v=Qd6icOF1MV8
Backstory: 500 HP Camaro, the car sounded like that when we pulled it off the trailer for the final race of the season. I could either win the local championship or drop to 2nd pending the results of that race. The car owner said, "It's broken anyway and I've got a spare axle at home, go for it!"
Long story short, I won the championship anyway because the 2nd place guy finished a bit too far down the order that day.
Old Apr 29, 2008 | 05:23 PM
1320performancefreak's Avatar
i am local from you. i have a mint condition diff if urs is mess up. :-)
Old Apr 29, 2008 | 06:08 PM
ronnuke's Avatar
Originally Posted by tekstar,May 7 2007, 01:24 PM
If your diff is broken, what kind of noise would it make? Is it loud? I have searched this before but have never really found a straight answer.
At low speeds I can hear sort of a "card in bike spokes" sound, but it is very faint and could very well be my mind playing tricks on me after reading all of these posts.
I have never launched my car, and when I heard the sound I was just cruising... but I did buy the car used a little over 2 months ago so I have no idea how the previous owner handled the car.
Your problem sounds more like the infamous timing chain autotensioner going bad.
Search it and see if it is what ails your car.
I change my differential oil about every other engine oil change, ~ every 20000 miles (change engine oil ~every 10000 miles with Amsoil full synthetic) and differential oil with LE607 or the new LE1605.
I agree the Richmond 4.56 gears are the best for all around drivability and durability. Mine are cryo'd.
deepbluejh
Dec 5, 2013 11:52 AM
combats2000
Oct 25, 2009 08:19 PM
Ek_Jak
Aug 26, 2009 01:25 AM
krnboi4370
Dec 10, 2007 01:54 PM
mike_awkisbig
Oct 4, 2004 07:42 PM
