Distinct engine noise troubleshooting
Old Jun 26, 2019 | 10:44 AM
F1TwoThousand's Avatar
Default Distinct engine noise troubleshooting
Would appreciate some advice on what to look for next time i have a chance to tinker with the S2K. Engine sounds and runs very smooth and quiet except for a clacking noise. Brand new built head was installed(head was upgraded car ran perfect, no noise before)
Old Jun 26, 2019 | 11:41 AM
engifineer's Avatar
I cant turn my volume up very loud right now, but what I do hear may be an exhaust leak in the manifold. But, maybe it sounds different with the volume up higher
Old Jun 26, 2019 | 12:45 PM
Its more of a metallic clank thats the issue, the rest sounds alot louder on video than in person. In the second video its more pronounced. Im going to remove valve cover and check valve clearances and cam bearings. Hopefully i just forgot to tighten a valve adjuster or something simple.
Old Jun 27, 2019 | 12:48 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Define “head upgraded”...
Old Jun 27, 2019 | 01:21 AM
Ported cylinder head, ferrea valves, springs, retainers, and bronze valve guides. Oem cams.
Old Jun 27, 2019 | 03:12 AM
Also i disabled each injector and ignition coil per cylinder. No noticable difference was heard.
Update: Cyl#3 intake valves were bent. Engine was cranked with timing chain disconnected
xxS2000guyxx
Feb 19, 2012 06:06 AM
Pinchy
25
Feb 11, 2009 02:08 PM
CR EH
Sep 4, 2008 03:26 PM
