DIY: soft top adjustment?
Originally Posted by Slows2k,Dec 29 2006, 12:46 AM
That's a stop for the roof in the down position. It's not adjusting anything on the top frame. Also not going to help you windnoise with the top up. You'll never have to mess with unless you have to replace a top motor.
Originally Posted by trich1687,Dec 28 2006, 04:21 PM
Your wind noise is caused by worn latches. Take a look at the part that the hook catches onto at the latch on the whindseild cowl. It most likley got a worn spot or grove where the hook engages. A temporary fix is to slide some rumbber tubing over the hook untill you replace the latch.
take a look at these, and tell me what you think. call me crazy but i don't think thats normal as seen on the pictures below i can stick my finger all the way on left crack of the joint frame (side where im getting wind noise) and i can barley put it in the right side
Left side>>>
right side>>>
